on 16-04-2023 13:07
Can anyone help I’ve plugged my phone into the hub 3 it works fine but the extensions won’t connect to the base unit they just keep searching and then fail to connect they all worked fine before
on 16-04-2023 13:57
Hi twotellys,
Thank you for your post. I'm very sorry to hear about the issue with your Landline service.
I have taken a look on our side and it looks as though you have been able to speak with the team regarding this.
Please let us know if you need any further assistance.
^Martin
