How to use landline phone while HUB 5 is in modem mode as using Mesh WiFi: TP-Link Deco S9 as router
68nic
Has anyone got any ideas how I can connect my landline phone to my Mesh WiFi TP-Link Deco S9 as my HUB 5 is in modem mode and Deco is now my router . I do have the adapter virgin media sent to plug my landline into my HUB 5 But its in modem mode .
2 REPLIES 2
Hi 68nic
Even though the hub 5 is in modem mode  you just need to plug the adapter into the TEL1 port on the hub 5 and it will work.
Dave
The do's and don'ts.
Thank you I didnt think it would work in modem mode. Ive been looking for adaptors to fit onto the Deco . Made my day 😀
