Sign in
Sign out
on 31-05-2022 17:57
I might be able to move main base of phone to electric socket nearer hub but it would only be 44cm away.
Is that alright?
Otherwise I will need engineer to install a cable from hub to main base?
Answered! Go to Answer
on 31-05-2022 19:26
Hi Soos_Mc,
Thank you for your post.
I don't see how this would be an issue at all to be honest with you 🙂
Cheers,
Ryan.
Found this answer helpful? Share it!
