Chickenpool
  • 7
How do i make incoming calls go straight to voicemail?
Hello,
Just a quick question. How do I make all incoming calls on my landline go straight to my voicemail without it ringing?
Cheers,
Micheal H
DJ_Shadow1966
  • 6.87K
  • 1.32K
  • 1.9K
Re: How do i make incoming calls go straight to voicemail?
Hello
I am afraid that what you are asking for is not possible the phone line has to ring before a call will go to voicemail after a certain amount of rings and that can be set by support from 3 to 10 rings before the voice mail picks up.
The only other way to stop the phone ringing is to place the phones ringer on silent.
Regards Mike
Zak_M
  • 3.53K
  • 223
  • 353
Good morning @Chickenpool.
Welcome back to the forums and thank you for taking the time to post.
As advised, we are not able to send your calls to voicemail right away however we can change the rings before voicemail cuts in,  If you would like me to change this for you then please do let me know.
Kind regards,
Zak_M
