Home phone to fibre switch over query
V15h44l
I just received an sms from a mobile number 07828563xxx:
Hi, it's Virgin Media. On 15th January 2024, your home phone service will be switched to our fibre network. We'll send you an adapter(s) as you need to connect your home phone to the Virgin Media Hub so you can continue using it. Reply with ACCEPT to be switched over or with CALLBACK if you need help.
Firstly, I would like to check this is legitimate
Secondly, I use my virgin media hub as modem only mode and use a 3rd partyWi-Fi mesh system as it’s better coverage than the standard ISP provided hub. Will the phone port still work in modem only mode? I do not want to use the hub for Wi-Fi!
[MOD EDIT: number edited in case it's an innocent number being spoofed]
0 REPLIES 0
