on 23-07-2022 13:52
I have my hub set to through mode, should I still plug the adapter into the hub when I switch over to digital phone line?
Do I need to make any config changes to hub?
on 23-07-2022 13:57
Hi Gesmond,
Thank you for your post. My apologies, but I'm not sure what part of the setup you're up too.
Once you have plugged in the adapter you just need to plug the handset into it.
^Martin
on 23-07-2022 14:05
@Gesmond wrote:I have my hub set to through mode, should I still plug the adapter into the hub when I switch over to digital phone line?
Do you mean your hub is in modem mode rather than router mode? In any event, your phone plugs into the VM hub (using the VM adapter) once you have been switched over.
on 23-07-2022 14:10
Yes Hub is in Modem mode, not due to be switched over until next week.
Just wanted to check that I still can just plug into Hub without having to do anything else
on 23-07-2022 14:39
Thank you for that information. That is correct.
^Martin
