id52
Message 2 of 5
Home phone not working
My home phone has no dial tone and I'm unable to receive calls. Last known to be working on Sunday.
Have had Virginmedia package for many years, TV and broadband are still working. There have been no changes recently to home infrastructure or equipment.
Have:
  • run tests on kit (result: 'inconclusive');
  • tried alternative handset, removed extension lead and plugged in directly to Virgin socket (result: still not working;
  • checked the service status (result: no known issues); and
  • checked bill payments (result: up to date).
Next step is to arrange technical support and/or book, if required, an engineer as soon as possible.
Can some one help shed some light on why my landline is dead and how to get it fixed?
*** UPDATE*** next door neighbour (also on virgin) has same fault
id52
Message 1 of 5
Moved to correct area
Martin_N
  • 8.05K
  • 339
  • 495
Message 3 of 5
Re: Home phone not working
Hi id52,
Thank you for your post. I'm very sorry to hear about the issue you're having with your landline.
As you have already done those check it does sound like an engineer is required for this.
I am unable to locate your account on our side and so what I will do is private message you to get some details.
^Martin
id52
Message 4 of 5
Thanks to Martin - it turned out to be an area fault which has now been rectified.
Martin_N
  • 8.05K
  • 339
  • 495
Message 5 of 5
I'm glad to hear this has all been sorted for you.
^Martin
