hbhann
Home phone not recieving / making calls
We were unable to make or receive calls on our home phone about 2 weeks ago, called up and managed to get through to someone but got cut off part way through, however the phone started to work so we didn't worry about it. Now it has stopped working again, incoming calls just get a busy tone and we are unable to make any out going calls either. Our phone is plugged into the wall socket.
We can't even get through to the virgin customer service number to try and fix it this time.
Hoping for some kind assistance / advice.
Tags (2)
Zoe_F
  • 422
  • 115
  • 140
Re: Home phone not recieving / making calls
Hello, if you can send me a private message with your account number and are code/postcode and i will look into this for you
To send a PRIVATE MESSAGE please hold over my name until the option send message pops up.
Zoe
If I've helped in any way, please give me Kudos and mark my response as a helpful answer!
Fancy £50 off your bill? Ask me how and you might just get it!
I am a serving Field Technician at Virgin however all responses on here are based on my experiences in the field alone and my own equipment at home and should be taken as such
kizi
  • 210
  • 41
  • 38
sorry to hear that I hope I can help you I will pm you to get some details there cause be a loose wire some where
