28-09-2022 16:13 - edited 28-09-2022 16:14
my home phone was due to switch over to fibre on the 26th September and the line is not working at all. I have checked it’s plugged into the correct phone port (not the Ethernet port) with the virgin supplied adapter.
My home DECT phone is is quite old, maybe 5 years? Is this the issue ? Any advice would be great.
thanks,
Rich
Answered! Go to Answer
on 28-09-2022 16:49
Lovely stuff Kain,
Tried a different phone and it worked, so that explains that!
thanks for your help mate,
Rich
on 28-09-2022 16:22
Hi there Rich4rd78,
Thanks for your post and welcome back to the community.
Many apologies for the landline issues, to clarify are you receiving no dial tone whatsoever?
Let us know,
on 28-09-2022 16:25
Hi Kain,
No, nothing at all. The phone is displaying “Please check line cord”
Rich
on 28-09-2022 16:28
Ahh okay, thanks for getting back to me.
Is that the only handset you have as well or can you try another one?
Cheers,
on 28-09-2022 16:37
@Rich4rd78 wrote:Hi Kain,
Rich
Rich, just out of idle curiosity, have you tried connecting the phone back in to the old wall socket? It is quite possible that the switchover never actually happened.
on 28-09-2022 16:49
Lovely stuff Kain,
Rich
on 28-09-2022 16:53
No problem at all!
I'm glad that's sorted for you now, if you do have any future issues then be sure to pop back up to the team for further assistance.
All the best,
