on 07-12-2022 17:49
Recieved the new adaptor to switch my phone to fibre network.
The adaptor does not fit my wall socket.
My hub is up stairs in the spare room, can you advise how I can get my phone to operate.
Answered! Go to Answer
on 07-12-2022 17:53
Hi @Gerry9870 thanks for your post here in the Community, although I'm sorry to hear of your concerns raised here about the switchover.
To be clear here, the phone needs to be directly connected into the Hub itself, so would be need to be placed near your Hub.
If you look into the back of your Hub, you'll see a port named TEL in the back of this - the adaptor will go in there, and your landline connected into the other side of the adaptor.
I hope this helps!
Many thanks
on 07-12-2022 17:53
I hope this helps!
Many thanks
on 07-12-2022 17:58
No it doesnt help.
I understsnd the process to connect. The issue is I am unable to as my landine is doenstairs and my hub is upstairs. There is no phone line upstairs.
on 07-12-2022 18:01
Hi @Gerry9870 thanks for your quick reply.
So there doesn't need to be a phone line upstairs, the phone line is the connection between your Hub and Landline - can you try plugging your landline in upstairs in the spare room, and connecting your landline directly into your Hub to see if this works and there is a dial tone?
Many thanks
on 07-12-2022 18:25
If I remove my phone from downstairs, and connect to the spare room, then yes I have a dialling tone.
Doesnt resolve the issue as my phone base is downstairs
on 07-12-2022 18:31
@Gerry9870 wrote:If I remove my phone from downstairs, and connect to the spare room, then yes I have a dialling tone.
Ask VM (via the VM forum team on here) to modify your home phone wiring so you can use your existing landline extension sockets via the phone connection from the VM hub.
VM should offer to do this free of charge for you as part of the switchover process.
Make sure they make modifications to your phone wiring so you can keep each piece of equipment in the same place (rather than the offer which sometimes crops up on here to move the hub to a different location)
Refer here
https://www.virginmedia.com/help/landline/switchover
Do I need to book a technician visit?
You’ll need to book a free technician visit if...
on 07-12-2022 18:40
I need asdistance to modify my home phone wiring so you i can use my existing landline extension sockets via the phone connection from the VM hub.
I want the phone access to remain in the livingroom. Happy to have the hub reinstalled downstairs.
on 07-12-2022 18:51
Hi @Gerry9870 thanks a lot for your reply - understood.
Please allow me to send you a PM so I can look into this further for you.
Kindly expect the PM from me to arrive shortly, and respond directly when you can!
Many thanks
