Fibre Phone
STMc1970
I have connected the new adaptor to the back of the hub and have a green phone light on. But I have no dialling tone on the phone.
What do I need to do?
8 REPLIES 8
Kain_W
Hi there STMc1970,
Thanks for your post and welcome to the community.
Apologies for any service issues, is the switchover date been advised as today as well?
Let us know,
Kain
No the switchover date was 6th December.
Thanks for the response,
Just to clarify on the setup, do you have a DECT powered handset?
Also is your phone station able to connect to the fibre line without the adaptor?
Regards,
Kain
It’s a cordless phone but a very old one. And no I can’t connect the phone line directly to the hub as there aren’t any ports of that size
Right okay,
So is the phoneline not connected through the adaptor at all?
Secondly is that the only phoneline you have i.e. no extensions?
Thanks for your patience,
Kain
The phone line goes through the adaptor into the hub. And it’s the only phone line I have.
No worries,
So we can run further checks on this I've dropped you a PM.
The message will appear within the purple envelope icon.
Regards,
Kain
Kain_W
Thanks for your cooperation over PM STMc1970,
I'm glad the issue is now resolved for you.
Do pop back up if you require further assistance.
Take care,
Kain
