Fibre Phone Switchover
Samcod
Just joined
Switched over today with adapter as per instructions, but landline not working.  I've checked the connections to the hub, rebooted as per instructions and is still not working.  Have tried calling to be told that tests will be carried out on my line and phone back in 10 mins.  This was about 2 hours ago and everytime I phone up I keep getting told that tests are still running call back in 10 mins.  Can someone please help?
1 ACCEPTED SOLUTION
Accepted Solutions
Megan_L
Hi Samcod,
Thanks for using the forums to get this issue with your landline switch over looked into, I am sorry if this has been causing some frustration.
The home phone switchover usually takes 24 hours to fully complete, so this may be why your landline is not working at the moment due to these tests ongoing today.
I would wait until tomorrow to test out your landline, if it's still not working properly please do these steps first before coming back to us -
  • Check the phoneline is plugged into your Hub correctly and tightly.
  • Reboot your Hub.
If it is still not working after a reboot then further diagnostics as well as an engineer may be needed.
I'll reach out to you tomorrow anyway just to check on how things are.
Speak to you tomorrow.
Megan_L
3 REPLIES 3
Megan_L
Hi Samcod,
  • Reboot your Hub.
Megan_L
Phone working fine now for incoming and outgoing calls. Thanks Megan. Regards, Sam
Hi Samcod, thanks for getting back to us.
And thanks for confirming your issue has been resolved. Remember, if you ever need assistance in the future, our fantastic community and forum team are always willing to lend a hand. Also, please bear in mind that our website offers lots of helpful information and also, you can manage your account from here.
Lee_R
