on 22-05-2023 15:45
Hello.
The new fibre phone cable we have been delivered will not reach our hub. The Hub is upstairs, and the in-wall phone cable is downstairs. What should I be doing?
Bailey
on 22-05-2023 15:50
Ask VM (via the VM forum team on here, when they reply to this topic) to modify your home phone wiring so you can use your existing landline extension sockets via the phone connection from the VM hub.
VM should offer to do this free of charge for you as part of the switchover process.
Make sure they make modifications to your phone wiring so you can keep each piece of equipment in the same place (rather than the offer which sometimes crops up on here to move the hub to a different location)
Refer here
https://www.virginmedia.com/help/landline/switchover
Do I need to book a technician visit?
You’ll need to book a free technician visit if...
on 22-05-2023 15:51
HI BaileyBrooke,
Thanks for your post and welcome to the community.
Sorry to hear you're experiencing issues with setting up the phone line, just to clarify are you unable to co-locate the handset you have with where the Hub is placed? As that is all what's needed as opposed to the prior phone cable set up.
If not then our team will be able to support with this?
Regards,
on 22-05-2023 20:56
Hi Kain, thanks for your swift response.
The phone line is plugged into the wall, downstairs, and the hub is in my bedroom, upstairs — I have no real way of getting the cable to the hub; as such our landline is currently down. We were delivered the new adapter, no problem, I just can’t use it.
Bailey
on 22-05-2023 20:57
Oh, sorry, I misread you. I don’t have a handset in my bedroom, no, the closest is in an alternate bedroom but that will not reach either.
on 23-05-2023 08:09
Thanks for the reply @BaileyBrooke on the forums. 😇
I'm sorry to hear about the hub not reaching the landline.
We can arrange an appointment to get this moved for you so that both services work.
I will send a private message.
Kind regards,
Ilyas.
