Bill1a
Dialling Tone missing & Intermittent single ring
I can't use my landline, I don't have a Virgin mobile and phoning from my mobile will be expensive, especially if kept hanging on. I've had the problem since 3pm yesterday, it keeps giving a "strangled" ring, as if it is being tested, I have done all the sugessted "help" checks and it is the same problem I have had before which was solved without a visit to the house. I believe it was water in the local distribution box!
Serena_C
  • 814
  • 39
  • 82
Re: Dialling Tone missing & Intermittent single ring
Hi @Bill1a,
Welcome to our Community Help Forum 🙂
Thank you for making your first post regarding the issues you have having with your landline.
I have scheduled an engineer visit for you to get these issues resolved. I will send you a private message now with the details of your engineeer appointment and to confirm your address.
Please look out for the purple envelope in the top right corner.
Best wishes,
Serena
