DOCSIS conversion question
Anonymous
Not applicable
(Guess this is phone related.........dunno) if not correct move it
So yesterday I got my phone line from virgin converted to DOCSIS I obviously have a virgin phone box installed weird thing is shouldn't have that stopped working? if the connection runs through the docsis now? as apparently that appears to still be working too. Will that go off eventually?
5 REPLIES 5
Corey_C
Moderator
Moderator
Hi johnsemple123,
Thanks for your post. Any device or service that you may have had running through the standard phone line [ POTS] will get switched off unless you have connected them to your DOCSIS service.
Cheers,
Corey C
Anonymous
Not applicable
What I mean is that phone line that was converted is still working at the moment................? I guess it will go off soon enough?
Thanks for your reply, johnsemple123,
Yes, that will get switched off eventually.
Cheers,
Corey C
Anonymous
Not applicable
Just to update. PTOS part went off today at some point so now I am officially full DOCSIS
Hi @Anonymous thanks for getting back to us.
Thanks keeping us update.  Remember if you ever need assistance in the future, our fantastic community and forum team are always willing to lend a hand.
Lee_R
