alanthorpe
DECT phones will not ring on i/c calls
About a week ago our BT8600 DECT phones stopped ringing on i/c calls although an old POTS phone that shares the phone socket with a Y adapter does ring.  Various tests were done by removing the Y adapter and Extension sockets from play that suggested the DECT Base Station may be the cause. A new BT DECT 4600 system was purchased overnight and installed but this new system exhibits the same symptoms of not ringing on i/c calls. You can see the i/c call active on the DECT handset display and the call can be successfully answered on the DECT handset despite no ringing to alert you to the call. Outgoing calls are fine.
I believe that it is highly unlikely that 2 separate DECT systems would exhibit the same symptoms on a service that has previously worked ok. The fact that this problem started within the last week, when the weather changed for the wetter, suggests an issue with the strength of the exchange generated ringing current or the master socket ringing current capacitor / filter, or other changes at the exchange end..
Any ideas other than an engineer visit which I have scheduled for this weekend?
Tags (1)
jb66
  • 12.27K
  • 911
  • 1.78K
Re: DECT phones will not ring on i/c calls
Your ment to have 75v AC when it rings, I would guess your not getting that so a technician is required.  Modern dect phones don't need a capacitor so I doubt its anything you can fix
alanthorpe
Hopefully things will be restored to normal service at the weekend.
Martin_N
  • 5.56K
  • 232
  • 318
Hi alanthorpe,
Thank you for your post and welcome to the community.
I'm truly sorry to hear about the issue you're having.
As you already have an engineer booked in for this it should all be resolved for you.
Please do let us know how the visit goes.
^Martin
