Brian6
  • 13
Connecting phone to Virgin Hub
Years ago when it was, NTL, they put a little square box in my hall to connect my landline, it has been there ever since.
I am wondering if the phone can be connected directly to my WiFi hub, it has the phone sockets, but I cannot test it because the connector on my phone is not the same as on the hub.
Can anyone tell me if it will work, and if so where do I get the connector from?
jb66
  • 12.27K
  • 911
  • 1.78K
Re: Connecting phone to Virgin Hub
It won't work unless you upgrade to the new style of phoneline. Currently there is no procedure to do this unless your landline is faulty
Brian6
  • 13
So the fact that I am a long time customer of NTL/Virgin, that the phone is currently in a place I dont want it, is connected via a shabby old box, still means I cannot have it moved to where I would really like it? Why?
