Hello,
In the interest of fairness I have RE-read those pages and it seems quite clear that the onus is on me to ensure that everything will work after the change-over and to ensure the careline provider makes for adequate failover in the event of a power or telecoms outage on your part. At least OFCOM have changed the priority obligation to extend to broadband as well as just POTS.
Connecting to the Superhub3 will mean re-locating the Careline unit AND my cordless base-station. The new location is at one end of my property, not the current central point (the existing master socket is in the centre of the house). I do have alternative (cat 6) cabling which can be patched between the Superhub3 and the existing location - but will need help from an engineer for RJ45-RJ11 adapters/connections). This was installed during rebuilding work - but at the time I'd not anticipated being permanently stuck in a wheelchair...
So, here are the issues.
- I will need help from an engineer, per your documentation, to check and ensure prior to the changeover that everything will work 'on the day'. I presume your emergency lines can be pre-installed prior to 6th June? How do I book this? It is not documented anywhere I can see.
- On the day I will need to change over the connection from master socket to the adapter connected to the Superhub. What happens if things then don't work? Will additional engineers be available for same day repair visits?
- If you are unable to answer (1) and (2) above - what will your solution be?
It may seem I'm being a bit paranoid - but I've spent years of my professional life first planning complex IT related changes like this, and subsequently as the person reviewing and approving such changes. Quite honestly your activity would not pass muster as it appears to lack any testing plan, nor back-out option.
In addition, the Equality Act (2010) requires that you make reasonable adjustments, it is not enough to say 'you will need to book an engineer' without explaining how, and when. Your own 'accessibility and vulnerability' policy sets targets which seem to have been thoroughly ignored while planning this activity,
I'm not expecting miracles, nor to gain any service not anticipated by contractual or legal obligation. I ask only to be treated fairly and openly, without assumptions being made.
If my answer helped you, please mark it appropriately. It's always nice to be appreciated.
Stay Safe. Stay Healthy.
Andy Bundy
Remember: the answer I give is only as good as the question asked. The more relevant information you give, the better the answer you'll receive.
