coypu13
  • 51
  • 12
Dialled in
Can't answer incoming calls.
When my phone rings I pick it up and it just continues ringing. Working fine for outgoing calls.
Travis_M
  • 4.58K
  • 169
  • 335
Re: Can't answer incoming calls.
Hi @copyu13
Thank you for posting on our community forum
This seems likely to be a handset issue rather than something on our part, what happens when you pick the phone up and press the 'Answer' button - does this still continue ringing?
Travis_M
