  • 1.28K
  • 70
  • 118
dnpark38
Knows their stuff
Message 1 of 13
Calls cut out after 23 mins
My wife as had this fault several times now we have two daughters grown up and living in other parts of the UK both have their landline phones with BT
At 23 mins. into the call the call cuts out and as to be remade, anyone had this fault?
If so were VM able to fix?
"VM 50 Mps Broadband and anytime phone."
  • 1.63K
  • 86
  • 115
Message 2 of 13
Re: Calls cut out after 23 mins
Hi dnpark38,
Thanks for your post!
Sorry for the trouble you're having with the line, is it just these two numbers that have the issue cutting out, or have you noticed it with other numbers also?
Have you tried another handset? Is it a cordless handset you're using
Let me know if you still need help with this,
Kind regards,
ALEX_RM
  • 1.28K
  • 70
  • 118
dnpark38
Knows their stuff
Message 3 of 13
Yes have noticed on calls to another family member again which go over this time, of course all other calls are short.
I'm asking if other customers have had problem like this and were VM able to get to the root of the problem without difficulty?
  • 1.63K
  • 86
  • 115
Message 4 of 13
Thanks for getting back in touch 🙂
I'm not aware of other customer's having this issue and I'd like to help resolve things as quickly as possible for you.
If you can please let me know the following information so I can rule things out-
Any issues calling Virgin to Virgin numbers?
Do you get the issue when calling mobile numbers?
Are you able to test another phone handset?
Kind regards,
ALEX_RM
  • 1.28K
  • 70
  • 118
dnpark38
Knows their stuff
Message 5 of 13
Non of the family members which have these long calla are on Virgin.
Would be very unlikely we would have calls of long length to Mobiles.
Doubtful its the handset will try to eliminate.
  • 1.08K
  • 34
  • 63
Message 6 of 13
Thank you, please let us know how you get on.
Nat
  • 1.28K
  • 70
  • 118
dnpark38
Knows their stuff
Message 7 of 13
Update
Cut offs got more regular so booked an engineer and he came today, he found the fault was not in my cabinet but did find a loose connection in the main cabinet mine fed from.
So hopefully problem will be solved.
Thanks.
  • 2.87K
  • 94
  • 147
Message 8 of 13
Glad to hear it is sorted.
^Martin
  • 1.28K
  • 70
  • 118
dnpark38
Knows their stuff
Message 9 of 13
^Martin
Sadly not sorted, have ordered another visit from engineer for tomorrow.
  • 1.28K
  • 70
  • 118
dnpark38
Knows their stuff
Message 10 of 13
Different engineer today I explained what the other engineer had done so he as requested the engineer who deals the exchange cabinet about a quarter of a mile away to visit that during Monday.
Anyone know how the system works?
I suppose at some point it leaves Virgin network and goes and gets at some point into the National Phone network.   We seem to be working back away from me until the fault clears.
