Carstairs47
  • 17
Caller display doesn't work
Hi. I used to have caller display, but it hasn't worked for quite a long time now (possibly it was removed when I renewed my contract). Is it not a free service anymore? I don't use the landline much but I'm getting more spam / scam calls - despite being TPS registered - so it would be useful to know when I can ignore callers. I can't get through or get a response from the usual Contact options and have been trying for some time now.
Megan_L
  • 2.68K
  • 162
  • 281
Re: Caller display doesn't work
Hi Carstairs47,
Thanks for using the forums to get this issue with your Landline looked into, I am sorry if this has been causing some frustration. I would be more than happy to look into this for you, could you tell me if you've changed your landline handset since this issue started?
I will gladly help further after I know this 🙂
Megan_L
Carstairs47
  • 17
Hi Megan, thanks for replying. No, nothing else has changed. I've had the same handsets for a few years now.
Zak_M
  • 4.44K
  • 259
  • 421
Thank you for coming back to us,
Are you able to try an alternative handset?
Kind regards,
Zak_M
Carstairs47
  • 17
I've got two handsets at the home (connected to the same landline). Neither have caller display anymore.
Zak_M
  • 4.44K
  • 259
  • 421
Thank you for confirming that for me.
I am going to drop you a PM so that I can get some account information,  please keep your eye on the envelope on the top right of the screen.
Kind regards,
Zak_M
