lizzymadray
  • 18
Message 1 of 9
Cable phone
what cable do I need to connect my phone to virgin fibre phone adapter? As in how many pins in connector - does it matter?
Beth_G
  • 4.8K
  • 276
  • 511
Message 2 of 9
Re: Cable phone
Hi lizzymadray.
Welcome to the Community Forums! Thanks for your first post..
Just to confirm, are you set up for voice over fibre connection (meaning that your landline would be plugged into your hub) or via your wall socket?
If you're on voice over fibre, you should have something called an RJ11 adapter which fits into the back of the hub (I assume this is what you're referring to in your post). I believe that most landlines only have one cable coming out, so it would be this cable that goes into the back of the adapter. It's almost like a 'B' shape
If you're still unsure, can you please confirm the make and model of your landline handset so we can try to assist further?
Beth
Beth
lizzymadray
  • 18
Message 3 of 9
Re: Cable phone
Plugged into my hub
lizzymadray
  • 18
Message 4 of 9
Re: Cable phone
I cant access the old cable that connected my phone to the original wall socket - as it runs under floors and behind cabinets and only the end tgar connects to the phone base is visible - the phone is a Gigaset C430 cordless
lizzymadray
  • 18
Message 5 of 9
Re: Cable phone
I have the adapter to plug into back of hub and it has several pins/contacts in the end that connects to the phone cable and I just want to be sure any new cable I connect to this and the phone base has the right number of pins/contacts to work properly
Beth_G
  • 4.8K
  • 276
  • 511
Message 6 of 9
Re: Cable phone
Oh right I see, it sounds like that would be the cable which you'd need.
If you've ever had your handset plugged into the wall socket, it would be that end of the cable you'd need to plug into the back of your hub.More information about the voice over fibre switch over can be found here
Kind regards
Beth
Beth
goslow
  • 3.72K
  • 527
  • 1.37K
Community elder
Message 7 of 9
Re: Cable phone
Your post is a bit hard to follow. Are you trying to replace the line cord lead which connects the phone base to the wall socket (because yours is currently hidden under the floor and cannot be removed)?
Presumably you can access the end of the lead that goes into the phone base. If so unplug it and you will see how many pins are in use. It will probably be just two in the centre of the plug.
If you are seeking that lead, then the one for my own Gigaset C475 cordless (which is a much older device by the look of it) requires two pins to be connected on the plugs.
RJ11 plug Pins 3 and 4 (centre two pins) which goes into the phone base
BT plug Pins 2 and 5 which goes into either the wall socket or the adapter on the back of the hub depending on how your VM phone service is provided.
The hub itself only uses 2 pins in the TEL1 socket on the back.
lizzymadray
  • 18
Message 8 of 9
Re: Cable phone
all done
Zach_R
  • 3.79K
  • 125
  • 269
Message 9 of 9
Re: Cable phone
Hi @lizzymadray,
Thank you for the update. Is this now sorted, or do you still need our help with this today?
Zach - Forum Team
