@Kevster57 wrote:
Thanks for the info ,,, so basically pick a call barring option colour , and all the calls listed under that colour are barred
For clarity, the colours mentioned in the phone guide refer to your phone connection's colour 'zone' (not directly the barring options).
You can find your phone colour zone as per page 3 in the linked VM phone manual (by dialling 1765 from your landline).
Once you have found out what colour zone your phone is connected to, you can see the options available for call barring for that particular colour zone.
