Isochris
Message 1 of 7
1571 not working on landline. Please help to reset as it does not reset by 1571 alone
1571 not working on Home phone despite reseting many times it does not reset. Please help
Gareth_L
  • 6.18K
  • 379
  • 675
Message 2 of 7
Re: 1571 not working on landline. Please help to reset as it does not reset by 1571 alone
Hello Isochris
Sorry to hear 1571 is not working
Do you have the stuttered dial tone that indicates a message is waiting
Also when you dial  your own line do you get the voicemail option
Gareth_L
Isochris
Message 3 of 7
Thanks for replying Gareth_L.
We no longer have any stuttered dial tone or voicemail option, 1571 no longer connects to any caller.
It needs putting back onto our landline somehow. If I dial 1571 I get the "You have no messages"  but it does not work again with any caller.
Gareth_L
  • 6.18K
  • 379
  • 675
Message 4 of 7
Hello again Isochris
Thanks for the explanation
This is an easy fix and can take 48 hrs to get the voicemail back on
I will need to send you a private message to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_L
Gareth_L
  • 6.18K
  • 379
  • 675
Message 5 of 7
Thanks for passing security Isochris
I have added the Voicemail option to the landline now
The only downside is it takes upto 48 hrs to be active.
It will be available from midnight Saturday
If its not let me know please
Gareth_L
Isochris
Message 6 of 7
Thank you Gareth_L for your very kind service. I will await this feature after 48 hours. Fingers crossed.
Gareth_L
  • 6.18K
  • 379
  • 675
Message 7 of 7
Hello Isochris
Just a quick message to see how the line is and if the voicemail is working now for you?
Gareth_L
