Stesmith92
  • 17
Why do I get better ping on WiFi than using an Ethernet Cable to my Xbox? Gig1 Fibre
I have the Gig1 fibre broadband & for some reason I’m getting better ping on WiFi than actually connect an Ethernet cable from Xbox to my router. Anyone know the reason why?
Iamgroot
  • 20
Re: Why do I get better ping on WiFi than using an Ethernet Cable to my Xbox? Gig1 Fibre
Faulty Ethernet cable?
Stesmith92
  • 17
Tried two different Ethernet cables, one a brand new Cat5 cable. Still getting the same results
Stesmith92
  • 17
Closed
RedGooner
  • 1.95K
  • 69
  • 260
Super solver
Re: Closed
If not cable, its either the network port on xbox or superhub.
Red (VM SH2 AC Beta tester)
Running on 1Gbps VM service with SH4 in Modem Mode, with a ASUS GT-AX6000 router. With this setup I get Fantastic WIRED and WIRELESS Signals in my home. I dont work for VM. But I work in IT, and I know my tech.
My advice is at your own risk. If you are happy with my answers please press Kudo ?
hortonj88
  • 350
  • 8
  • 64
Fibre optic
If you're getting better ping over WiFi than over ethernet that's a sign there's an issue either with the ethernet cable, ethernet port on xbox or a faulty ethernet port on the hub.
Try a different ethernet port on the router?
Previously M200 (Left due to utilisation)
Now: BT FTTP 900/110 connected an ASUS RT-AC86U router.
https://www.speedtest.net/result/12098955842.png
