sguinzo_uk
Message 1 of 7
Ps4 Pro + 200mb contract but upload speed problem
Hi there everyone.
I just jump into virgin family and I'm really happy. previous provider was bt and I was totally unsatisfied with their service. Anyway let's go to my issue.
I try to put the ps4 in DMZ to have a good upload speed to stream and obviously a better responsive game. but im unhappy to see I can't come to 20mpbs. actually I've tried  everything, port forwarding, dmz mode. Nothing has worked for me. I still stay in 3.9 sometimes 6 maybe 7mbps. my aim is at least 15mbps. Someone have the same problem or want to increase the upload speed like me? please heeeeeeelp. Thanks for who's gonna spend time to help me in this
CHEEERSSS
Martin_N
  • 4.92K
  • 200
  • 276
Message 2 of 7
Re: Ps4 Pro + 200mb contract but upload speed problem
Hi sguinzo_uk,
Thank you for your post and welcome to the community.
I'm very sorry to hear about this. Can you confirm if this same speed is on other devices?
^Martin
sguinzo_uk
Message 3 of 7
Hi Martin,
well on my Speedtest on Mac the speed of down are 212mb and up 21mb.. that’s why I think have something wrong with the set up in the PlayStation. I’ll try to discover my best MTU and apparently is 1478 and I set my hub 3.0 with this and setup as well on the console. But I still have 6/7 mb in up. Btw The PS4 is in WiFi modo 5ghz solo mode
apcyberax
  • 33.4K
  • 1.87K
  • 5.94K
Message 4 of 7
DMZ or port forwording will not effect the speed
sguinzo_uk
Message 5 of 7
Good to know. Thanks for the info
ZiltoidRacer
  • 111
  • 6
  • 20
Up to speed
Message 6 of 7
PS4 speed test is absolute rubbish and will not help you determine your upload speed, i have just done 3 internet connection tests in  less than 30 seconds and it ranged from 2.5Mbps to 7.0Mbps so as you can see it is rubbish.  I would say just stream and don't worry about the upload speed unless you have a problem because you will send yourself nuts using the PS4's test as it's not very accurate or good, base your tests from your mac and if that is ok then just stream and save yourself all the agro of trying to get upload speeds to where you want them when the test your using is crap basically.
https://www.twitch.tv/ziltoidtv
Aaron2
  • 759
  • 85
  • 130
Rising star
Message 7 of 7
Try MTU 1450
** I work for VirginMedia but all opinions posted here are my own.
