Low upload speed and constant packet los for over a week.
Dominix
Hello.
Since 16th of October, I'm getting constant packet loss
https://www.thinkbroadband.com/broadband/monitoring/quality/share/9b6b3598af00df0d3591e13b88d7950961...
this from Monday:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/076434d7e861d23da56ca1ddb922a9617b...
service status website says:
Broadband
There are no known broadband issues in M23 1LT.
after checking hub I'm getting this message:
Looks like there are issues in your postcode affecting your services
There’s a broadband issue in your area and our technicians are on the case to fix things. Check back here at any time for updates.
And it has been like this for around a week. I check status every day and it's always the same message.
UP speeds are around 1/3 or even lower:
3 REPLIES 3
John_GS
Hi Dominix
Thanks for posting and welcome back to the community. My apologies about the low upload speed. I have done a system check and you are affected by an SNR issue (signal to noise ratio). F010196363 - this is the fault number. The estimated fix date is the 2nd November. Please monitor the connection after this time and report back any issues.
Best wishes
John_GS
Hello John_GS
Thank you for reply.
2nd of November 😭😭😭
I hope it will be fixed by this time. And for sure will update if anything changes.
@John_GS
So as for today
Speeds are better
but still have a bit of packet losses
less than before but still persist
also, diagnostic check still shows me this message:
