Nickbailey1
Position of hub and TiVo box
Can the TiVo box and WiFi hub be boxed in, or in a cupboard, or does it need to be visible in the room to work?
DJ_Shadow1966
  • 7.11K
  • 1.36K
  • 2.02K
Re: Position of hub and TiVo box
Hello
The Tivo will need clear line of sight as the remote for that is IR, with the hub you can place it in a cabinet if you require it may reduce the wireless signal a little depending on the make up of the cabinet.
Regards Mike
  • 8.46K
  • 675
  • 1.51K
If you have a V6, often incorrectly referred to as a TiVo (which is another type of box), then it can go in a cabinet as the controller can use RF as well as infrared.
