First thing - please only create one post for a particular query, and don't add "me too" to someone elses thread - I've fixed all that for you now. Rant over 😉
There's two thousand-dollar questions in this scenario I suspect..
1: Are you a current VM customer? If you're not, then VM are only likely to be interested in resolving issues with their kit that are causing H&S issues.
2: Is this causing a H&S issue? Adding some photos to this thread, will help others advise.
If the answer to both questions is "no", then the chances of VM being interested are at best slim. Removing kit that's not causing an issue potentially impacts on their ability to offer expedient future installations at your address.
