Nbc1972
Message 1 of 10
Hub3 white base led changed to red.
Base led was white now red in colour. WiFi keeps dropping out. The unit isn't overly hot. Tried the reset still the same just concerned with overheating issue.
Anankha
  • 2.13K
  • 162
  • 484
Problem sorter
Message 2 of 10
Re: Hub3 white base led changed to red.
Have you tried turning the hub off & leaving it to cool down?
Is it in any enclosed space?
Nbc1972
Message 3 of 10
Hi left off overnight and is sat in open space.
Anankha
  • 2.13K
  • 162
  • 484
Problem sorter
Message 4 of 10
Then it’ll most likely require a new hub. please await a response from a mod or VIP.
  • 7.96K
  • 639
  • 1.38K
Message 5 of 10
Try a pin hole reset on the hub, it may possibly fix this.
Nbc1972
Message 6 of 10
Thanks but already tried the reset.
Anankha
  • 2.13K
  • 162
  • 484
Problem sorter
Message 7 of 10
That was the first thing I tried & it doesn’t work.
Emma_C
  • 8.28K
  • 512
  • 547
Message 8 of 10
Hi Nbc1972,
Really sorry you've been having an issue with your hub, this ins't good.
I can appreciate you posted last Thursday so I've checked the back end of things and can't see any obvious issues.
Are you still having problems with the hub now?
Let us know and we can assist further via PM if needed.
Emma_C - Forum Team
Nbc1972
Message 9 of 10
Hi Emma
The hub continues to indicate a red led and I'm having to reconnect the WiFi to connected devices several times a week. My devices indicate WiFi available then no Internet connection. Eventually I manage to get them connected. This isn't an ideal suitation for the price I'm paying for the services provided.
Paul_DN
  • 5.31K
  • 311
  • 557
Message 10 of 10
Hi Nbc1972,
Thank you for coming back to us, I have had a look our end and cannot see any issues at all, your levels are all where they should be,
I would advise you to set up a free “Broadband Quality Monitor” to continually monitor the state of your connection and record any network dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with us. Make sure you un-check the “ignore ping from WAN side” box in the settings if you see a wall of "red" - note it will take an hour or two to start seeing a sensible picture. you can find it here .
Kind regards
Paul.
