Noreen_93
Message 1 of 16
Green cabinet blocking front driveway
There is a green cabinet obstructing our driveway that could potentially hold another car if not for the cabinet being there blocking entry. Open Reach have stated the box is not theirs and suggested I contact Virgin Media. Could I request a removal and/or suggestions that could rectify my problem. Thanks.
Pars
  • 136
  • 20
  • 29
Superfast
Message 2 of 16
Re: Green cabinet blocking front driveway
Is this a cabinet that has only just been installed?
M350 over FTTP
Noreen_93
Message 3 of 16
No it's been in front of our property since we moved 3 years ago - not sure how long before then. We never needed to expand the driveway until now so it wasn't an issue previously. Thanks.
wez
  • 416
  • 37
  • 119
Fibre optic
Message 4 of 16
The cab is going to be costly to move (talking thousands), and at your expense, and owing to the current situation not likely to happen soon.
You can request it to be moved, but even if they agree you will have to contend with the above.
Noreen_93
Message 5 of 16
Could I get an idea of cost price? And if they refuse to move it could I get any benefits at all?
Pars
  • 136
  • 20
  • 29
Superfast
Message 6 of 16
I don't think it will be a question of costs as I can see no reason why they would want to move it.
Assuming your local road and pavement is adopted by the local authority, you have no rights over anything legitimately installed outside your property boundary.
Your only tangible opportunity to make this into an issue will have been when you bought the house.
M350 over FTTP
Anonymous
Not applicable
Message 7 of 16
£1000's Try £10,000's minimum.
You woukld have to replace all the cables going to it to every customer.
The box was installed in line with planning permission. It didn't block your drive.
Now you want to extend your drive this is one of the costs (if even possible) you will have to pay.
I wouldn't be supprised if it might end up costing £100,000 and everyone connected to it will lose service while hte work is done.
If the box branches out to other boxes you could be looking 10,000+ people losing TV, Phone and internet so VM may just flat out refuse.
DJ_Shadow1966
  • 6.87K
  • 1.31K
  • 1.9K
Message 8 of 16
Hello
VM would have to do a survey at your cost before giving you a quote for the work, then would have to factor in lose of service for everybody who is serviced out of that cabinet, and the work involved. The last time I saw a post reporting costs it was in the region of 10's of thousands.
The boxes are normally placed in the service area where VM have had permission from the local council.
Regards Mike
Noreen_93
Message 9 of 16
Before I close this case I need to confirm it even belongs to virgin media.
MissPasko
  • 1.83K
  • 221
  • 970
Message 10 of 16
https://www.telegraph.co.uk/money/katie-investigates/paid-virgin-media-16k-move-broadband-cabinet-dr...
~ ~ ~ ~ ~ ~ ~ ~ *\o/* ~ ~ ~ ~ ~ ~ ~ *\o/* ~ ~ ~ ~ ~ ~ ~ ~ *\o/* ~ ~ ~ ~ ~ ~ ~ *\o/* ~ ~ ~ ~ ~ ~ ~ ~
