  • 8
kendo74
volume code for remote
Hey guys I have a baird television and have tried so many codes to try activate the volume on the telly but none work... so far Smiley Sad
Does anyone possibly have a baird telly on here that can help? Smiley Wink
  • 5.46K
  • 151
  • 398
Re: volume code for remote
Hi kendo74,
Really sorry to hear about the trouble you've had with this.
The codes for Baird are as follows concerning the TiVo®.
You can also try this method: -
  1. Make sure your TV and your TiVo box are switched on.
  2. Press and hold down and at the same time, until the light on the top of the remote flashes green twice.
  3. Enter the code 0999 to access the TV code database - the LED will flash green twice.
  4. Press channel up repeatedly until a code turns off your TV - the LED will flash green each time a code is sent.
  5. When your TV turns off, use your TV remote to turn your TV back on.
  6. Press and to check that the remote is working with your TV. If it isn't working continue to search using channel up until the next code turns off the TV, and repeat steps 5 and 6.
  7. When the Volume and Mute keys work, press to store the code. The LED will then flash green twice.
If you are not using a TiVo®, there is more information regarding Virgin Media Remote Control Codes online.
Many thanks,
Nat_J
