Stutrumpet65
Yamaha receiver volume blacking out TV screen
Hi all,
Thought I'd share a solution rather than post a question as it seems quite a common problem.
yesterday I had my Tivo installed and the engineer synced the controller to my Panasonic TV
All seemed fine and he left me to re-wire my surround sound via my Yamaha RX receiver.  Connected TiVo to amp with hdmi 1 and amp to TV hdmi1 then ensured amp displayed hdmi1 and checked TV also input hdmi1
All OK and so turned TV inbuilt speakers down to 0 then turned up volume on amp - BUT every time I changed volume either by knob on amp or amp remote the TV screen blanked out for 2/3 seconds although sound continued.
Very frustrating - tried everything - one solution was to plug TiVo direct to TV and use optical cable TiVo to amp for sound - yes this works but can be problematic down the line!
The solution was to change the TiVo settings:
Home button
Help and settings
settings
video output
change to Video Output 1080i
choose the auto detect mode
Thats it - problem solved
PS - if those greyed-out channels annoy you just create a 'favourites' list -Smiley Happy
  • 7.22K
  • 281
  • 547
Re: Yamaha receiver volume blacking out TV screen
Hi Stutrumpet65,
A warm welcome to the community Smiley Happy
Thanks for coming by with a solution to your issue with the picture loss when you change the volume. This is a great help.
We're always here to help should you need us for anything.  Anything helpful is always welcome here Smiley Happy
All the best,
Collette.
