  • 9
Lima6
Subtitles - Is there a problem?
When using subtitles I frequently find that lines of text are missing or are overwritten with text remaining on screen after being said. Is this a fault with the signal or poor subtitling? It occurs on a wide variety of channels - am watching Criminal Minds on Sky Living HD at the moment and it's happening again!
  • 7.22K
  • 281
  • 547
Re: Subtitles - Is there a problem?
Hi Lima6,
Thanks for coming by Smiley Happy
I'm sorry to hear that the subtitles aren't displaying properly.  I'll be happy to check this out for you.
I have had a look in the office and they seem to be working ok at the moment.  I tested on the channels you mentioned you were affected by.
I have carried out some checks with the box remotely and there is a detectable signal issue which can impact on this.  I will arrange for an engineer to call out and get this sorted for you.
All the details will be in a private message I'll send to you now.  (Look for the envelope icon above)
