Raybrod
My Tivo running too slow
Hi Why is my Tivo running so slowly, if I press the red button it's currently taking 3/4 mins to load. At this speed it puts us off using it. But generally the whole service is slow, which you don't expect these days especially when paying £90 a month!!!
Tags (1)
  • 639
  • 68
  • 176
Argy
Rising star
Re: My Tivo running too slow
Press the Home button.
Then press Thumbs down, Thumbs up, Play, Play.
You should then hear a beep after a few seconds, the screen will blank for a few seconds. When it comes back, the box should be a bit more responsive.
Also, if you still have a viewing card, remove it. It's not needed on Tivos anymore, and removing it can speed up the responsiveness.
Just another VM user trying to help, so no guarantees that my advice will work .
If my suggestion is helpful, please mark it as helpful; it may help others. Just want to say "Thanks"? That's the Kudos button.
