  • 16
Ostragobulus
Message 1 of 1
V6 Box audio output jack
The V6 box has an optical audio output and what appears to be a 3.5mm jack connection.
Does anyone know the output voltage and impedance of this socket and whether using it will mute the audio output from the HDMI lead and the optical socket? I am assuming this is what the connection is?
I also note that the box has, what I assume to be mandatory with 4K boxes, HDCP 2.2 copy protection. This does not help when one only has one HDCP 2.2 activated HDMI input on the TV and when this is already being used by a UHD BD player!
A bit more technical information and a bit less childish language in the user manual would be helpful!
Many thanks
