Geoffers02
Using mobile abroaf
I have a mobile sim card pay monthly. I am in france ....how do i get the phone to work over here please?
  • 3.83K
  • 901
  • 1.7K
Re: Using mobile abroaf
Hi Geoffers02,
Before you left to go abroad did you check that roaming was active on your account?
Have you tried doing a manual search for network since arriving?
Log into your Virgin Mobile account then click on  the "Plan and device" tab.
Go to "Manage my services" > "Roaming" needs to be ON & "International call barring" needs to be OFF.
If they are not already, make the change by moving the "switch" in your account.
(Click the other side of the rectangle box).
If you have to make a change to the settings, allow time for your account to update then reboot your phone.
Virgin advise that this may take upto 24 or longer from abroad. I would periodically turn the phone off/on to see if it finds and selects a network.
Here is a useful help page from Virgin: Taking your mobile abroad
If you are still struggling and you are able to borrow a phone to call Virgin Mobile. Their UK support line number is: +447953 967 967
(There does seem to be quite a few problems with roaming at the moment, particularly in France Smiley Frustrated)
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
