Hobbie
Roaming
I am looking for the country code for Australia when I am actually IN the country, not calling it from outside or calling out from there. Help pls?
  • 7.23K
  • 808
  • 3.04K
Re: Roaming
Are you sure you are asking the right question?
If you roam, the GSM convention is that you dial local numbers as though they were international in format. So you would add +61 for Australia and discard any initial 0s if the country uses them.
In some cases you can get away with dialling local numbers in the local format. I have managed that in France but (AFAIK) it is not supposed to work.
In case this what you mean - the UK country code is +44.
Superuser 2016/17
Use Kudos to say thanks
Mark answer as "helpful" only when the problem is solved
Please don't send me private messages unless I ask you to.
I do not work for VM. The advice I give is based on my best understanding of VM policy and practice. You rely on it at your own risk.
