Jacqui1960
My phone wont work abroad
  • 3.81K
  • 894
  • 1.7K
Re: My phone wont work abroad
Hi Jacquie1960,
log into your Virgin Mobile account then click on  the "Plan and device" tab.
Go to "Manage my services" > "Roaming" needs to be set to ON & "International call barring" needs to be set to OFF
If they are not correct, make the change by moving the "switch/tab" in your account by clicking the other side of the rectangle box.
If you have to make a change to the settings, allow time for your account to update then reboot your phone.
(Virgin advise that this may take upto 24 or longer from abroad).
I would advise periodically turning the phone off/on to see if it finds and selects a network.
You may have to go into the phone's settings and do a manual search.
 Also check that roaming is enabled on the handset itself.
If you need to call Virgin Mobile. Their UK support line number is: +447953 967 967
AlexKid :-)
 If you want to say thanks > click 'Kudos'.
Answered your question? > click 'Mark as Helpful Answer' also.
