craigs09
Just joined
Connection
My phone isn't connecting to any network. I was recently abroad and my phone did not connect to a partner network. Since my return my phone has not reconnected to Virgin. So I have no service at all and cant receive or make calls and texts. What do I need to do to reconnect to Virgin?
Sam Craig
  • 3.84K
  • 902
  • 1.7K
Re: Connection
Hi Sam,
there are a couple of simple tricks you could try.
Are you on p.a.y.g or contract – is your account upto date.
If the battery is removable you could try taking it out whilst the phone is turned on, then replace it & turn the phone back on, This will reboot the phone.
Are you able to go into the phone settings & manually select a network?
If non of the above work, you could also try taking the SIM card out & putting it back again, then turn on the phone.
Good luck.
AlexKid :-)
_____________________________________________________________________
If you want to say thanks > click 'Kudos'.
If this has helped answer your question > click 'Helpful Answer' also.
