Message 1 of 2 (84 Views)
Australia - roaming
[ Edited ]
I have a sim only deal on two phones. I am going to Oz for a holiday, will I be able to use the phones over there if I switch on the roaming on my mobiles?
Thanks  in advance
Pete
[MOD EDIT: Post title edited to assist the community.
Problem sorter
  • 2.14K
  • 233
  • 558
Message 2 of 2 (51 Views)
Re: Australia - roaming
[ Edited ]
Yes Australia is covered, costs can be found here
https://help.virginmedia.com/system/templates/selfservice/vm/help/customer/locale/en-GB/portal/20030...
Before you go log into each account and turn Roaming ON and International call barring OFF, alternatively call 789 from each phone and follow the automatic prompts to check if roaming is on. Would also be a good idea to turn voicemail OFF before you go - each voicemail left would be at your cost, also turn mobile data OFF on your phone's - unless you don't mind paying £5 @MB.
BB 200 - Hub 3, Phone Talk w/ends, Mobile Sim only £9 and £5 big bundle sim. Customer since 1993.
