  • 7
Nimbamoss
Message 1 of 1
Speed going down by the minute!
Just got home from work, no wifi, wired ok, did a reset all back but speedtest dropped from 90 to 50 on a 200 line, did the ping test  and the online test online gave me this
Ok, we didn't find a fault with your equipment
If you've tried restarting your equipment and you've checked all the connections and you are still experiencing problems, then we'd be happy to investigate further.
Ping test gave me
Reply from 8.8.8.8: Bytes 64 Time=22.522 ms
Reply from 8.8.8.8: Bytes 64 Time=22.646 ms
Reply from 8.8.8.8: Bytes 64 Time=22.186 ms
Reply from 8.8.8.8: Bytes 64 Time=22.415 ms
Reply from 8.8.8.8: Bytes 64 Time=22.426 ms
Reply from 8.8.8.8: Bytes 64 Time=22.475 ms
--- 8.8.8.8 ping statistics ---
10 packets transmitted, 10 packets received, 0% packet loss
round-trip min/avg/max = 22.186/22.477/22.699 ms
Speedtest gave me
http://beta.speedtest.net/result/6962884941
For a 200Mb line. Any thoughts?
Ian
