RJMMultiTrade
Slow Speed Sub HUb3
Recently noticed slow speeds on my unto 200mbs broad band i did a speed test this morning and had a download speed of 6mbs. But when i do a service check online it says there a problem reset my equipment and try again in 10 minutes to know avail.
  • 178
  • 60
boltedenergy
Superfast
Re: Slow Speed Sub HUb3
When testing your connection to eliminate wireless interference, connect to your Virgin router directly with an Ethernet cable.
post your BQM results:
http://www.thinkbroadband.com/ping
post your speedtest results:
http://www.speedtest.net/
post your SH3 Puma test:
http://www.dslreports.com/tools/puma6
post your Downstream and upstream Router status:
Access your router web portal, usually http://192.168.0.1/ and post the screenshot of your Downstream and upstream results
Check VM Service Status:
http://virginmedia.com/servicestatus/
https://www.virginmedia.com/servicecheck/
Get Online/Contact Support:
http://help.virginmedia.com/
http://www.virginmedia.com/contact-us.html
SH3 specific latency issues:
http://community.virginmedia.com/t5/Gaming-Support/Hub-3-Compal-CH7465-LG-TG2492LG-and-CGNV4-Latency...
Reset your virgin router:
http://help.virginmedia.com/system/selfservice.controller?CMD=VIEW_ARTICLE&ARTICLE_ID=27643&CURRENT_...
Reboot your virgin router:
http://help.virginmedia.com/system/selfservice.controller?CMD=VIEW_ARTICLE&ARTICLE_ID=138977&CURRENT...
Guide to your virgin router lights:
http://help.virginmedia.com/system/selfservice.controller?CMD=VIEW_ARTICLE&ARTICLE_ID=27651&CURRENT_...
Troubleshoot your virgin router:
http://help.virginmedia.com/system/selfservice.controller?CMD=VIEW_ARTICLE&ARTICLE_ID=27595&CURRENT_...
Power Levels and SNR Primer:
http://community.virginmedia.com/t5/Speed/POWER-LEVELS-amp-SNR-A-TECHNICAL-PRIMER-updated-October-20...
--I'm just another virgin user like you. Please mark my answer as helpful, if it helped Smiley Happy
  • 4.3K
  • 91
  • 280
Moderator
Moderator
Hi RJMMultiTrade
Welcome to the forum. I'm really sorry to hear of the slow speeds you have been experiencing. I've run a check on your connection and I can see that there is currently a fault raised  causing slow speeds around peak times F003864632. Apologies for any inconvenience caused by this fault ticket. There is a review date scheduled for 05/04/2017 and we can certainly check closer to this date for any updates.
 As you ran a speed test in the morning it doesn't look like this fault will have had much on an impact on the result though. Are you testing your speed over a wired or wireless connection?
Speak soon
Ty
