foamcow
Not seeing improvement after speed upgrade
I was on 70Mbps Broadband for a long time and getting those speeds according to speedtest.net
Recently I have made some changes to my VM package which included a speed upgrade to the 150Mbps service. However I'm still not really getting much of an improvement over my older service.
I'm getting a rock solid 75-79Mbps but it's still nowhere near the 150Mbps advertised. Which makes me think it wasn't really worth the upgrade.
I'm pretty sure my setup isn't to blame but I thought I'd post here in case anyone can point at an issue there before I begin trying to get some settlement with Virgin Media.
I'm using a VM Superhub v1 in modem only mode with a TP-Link Archer C9 router. I've tested both Gigabit wired and AC wireless connections and get about the same speed with both.
Is there a way I can test further to determine whether or not the bottleneck is on my side or, as I strongly feel, on VM's side of the Modem?
  • 10.82K
  • 308
  • 632
Re: Not seeing improvement after speed upgrade
Hi foamcow,
Sorry to read there has been no improvement in speeds since the upgrade.
In regards to this issue, I have sent you a PM (purple envelope icon, right corner) with some additional information.
Look forward to hearing from you
Sam
