on 01-09-2023 00:08
I have 1 Gb internet speed and I want to take full advantage of my router, Hub 5. I connected a Cat 8 cable to port 4 but I still see a maximum of 1Gb transmit speed between my laptop and the router! I tried different laptops and different cables and they all maxed at 1Gb. My configuration is as follows:
1. Modem: Hub 5 using Port 4 for 2.5 Gb.
2. Cable: Cat 8.
3. Laptop network card: Realtek PCIe GbE Family Controller.
Is there a problem with my Hub 5, or is there something I should be aware of?
Answered! Go to Answer
on 01-09-2023 18:11
get this
on 01-09-2023 02:56
In order to maximise Gig1 using the 2.5GbE port of the Hub5 then both ends must be 2.5GbE. You are using a Gigabit network card hence 1Gbps.
PS. Most Cat8 cables are a scam.
on 01-09-2023 18:11
get this
01-09-2023 18:13 - edited 01-09-2023 18:13
@alsyefs wrote:I have 1 Gb internet speed and I want to take full advantage of my router, Hub 5. I connected a Cat 8 cable to port 4 but I still see a maximum of 1Gb transmit speed between my laptop and the router! I tried different laptops and different cables and they all maxed at 1Gb. My configuration is as follows:
2. Cable: Cat 8.
These three letters explain it all.
