  • 34
Hamrag
How do I measure my speed?
I'm supposed to have 100Mb/s.
Using JD's utility, I have 2.58Mb/s down and 1.33Mb/s up. Using all the speed testers I can find, I get figures around 3Mb/s down and 4Mb/s up.
If I do my own test, it took 3 minutes to download 422Mb, which is 2.34Mb/s. So the JD utility looks pretty close.
My Wireless Connection Status shows variations from 39 to 65 to 72Mb/s,
2.34Mb/s is a very long way from 100Mb/s or 39-72Mb/s.
What is the problem?
  • 8.36K
  • 362
  • 590
Re: How do I measure my speed?
Hi Hamrag,
Welcome to the Community!
Really sorry to hear you're experiencing speed issues.
I've located your account and I can see an issue with the network in your area affecting speeds at peak times - Ref.(F005074420). Our technicians are working to get this resolved and have set a review date of 17th May.
I'm really sorry for any inconvenience this may cause.
All the best
Josh
  • 742
  • 26
  • 149
MrHalfAsleep
Rising star
There are a number of speed test websites out there, some giving a "speedo" type display, whereas others use files to download:
Some popular ones here:
http://speedtest.net
http://testmy.net/
http://www.thinkbroadband.com/speedtest.html
http://beta.speedtest.net/
There are others available too.  Speeds can (and do) vary depending on a number of factors (e.g. how many users are online, time, faults, network congestion etc).
The only winning move is not to play.
No system is 100% secure
Ridicule is nothing to be scared of - Adam Ant
The only thing constant - is change. Chris Evans
The internet is a series of tubes
