d7rk
Message 1 of 1
Connection keep resetting
Hi community!
The speed with my SuperFibre 50 package is as expected.
However, the connection keeps resetting, even listening to an internet radio continuously for more than a few minutes is rare. It also interrupts navigation, downloads etc.
This happens on all devices (iphone, android, linux, windows and even internet radio) and multiple apps and browsers. It should therefore not be a problem of device or app configuration.
It also happens through wifi and through direct ethernet cable connection.
The  hub does not display anything special when the connection 'resets'. It is probably not a true reset, since any activity can usually be resumed fairly instantaneously.
Can anything be done?
Thanks for the help!
