Gem11
Wifi box
My internet box keeps resetting itself 3 to 4 times a day for no reason it's starting to get annoying as it will do it in the middle of watching something
  • 16.47K
  • 1.37K
  • 3.36K
Re: Wifi box
hiya @Gem11 welcome to the virginmedia community forum, would need to do a few checks on the hub, first off what hub do you have?, also need to check on signal levels by going to http://192.168.0.1 clicking router status top right [no need to login] and if could copy/paste the downstream, upstream, network log here.. don't worry about the formatting we can easily read it.
