  • 35
  • 5
Callinder
Superhub 2 WiFi problem
Although it doesn't happen all the time I've notice the more often than I'd like my router loses wi-fi. At the same time I cannot login to the admin interface of the router. As I mostly use a wired network I can often miss the fact that this has happened especially since I have a couple of wireless access points in my home that are connected via a wired connection to the router. The only solution is to reboot the router which isn't really satisfactory.
Has anyone got any idea what's the cause or is it a sign that the router is gradually failing?
  • 20.73K
  • 554
  • 3.21K
Sephiroth
Re: Superhub 2 WiFi problem
From what you describe, it's a known condition on some SH2s. There's a mega thread on this (search with the key word 'WEP') and see if you can find it.
The VM bods, when they are satisfied that yours is of that error type, will send you a new hub - now the Hub 3.
