Re: Solid red light on Hub 3
Tilnoom
Hi John_GS, I've also had a solid red light for a month after Customer Services told me it was doing a software update. It is warm to touch. Can you PM me too please?
Sharon
3 REPLIES 3
Please do not double post.  I've responded to your other post here Solid red light on hub for over a month - Virgin Media Community - 5461129
Ilyas_Y
Hey @Tilnoom Thanks for reaching out to us on the Virgin Media forums. 👋🏼
I'm sorry to hear about the issues with the red light on the VM hub.
A red light does indicate the hub is either faulty or overheating, as you have stated above.
Just before we continue, can you confirm if you have taken out all the cables, put them back in, rebooted the hub and ensure the hub is in an open place?
Let us know and we can go on from there.
Kind regards,
Ilyas.
Ilyas_Y
Tilnoom
Hi there, thanks for the reply. I have reseated all the cables, followed the reset guide, done the pin reset and it is indeed sat open on my desk in the same place all our hubs have sat for the last 10 years 🙂
